$35 Electric Power Steering with Fail-Safe - No eBay module and no caster issues!!!
Tested one more EPS / ECU that works in fail-safe/limp home mode with fixed level of assist. 2008-2011 Scion XD
2008-2011 Scion XD It's almost identical to Prius. The Prius, Yaris and Scion Xd ECU share same exact plug and works with each other.
ECU Part Numbers that function in fail-safe / limp-home mode:
2004-2009 Toyota Prius 89650-47102
2009-2013 Toyota Corolla 89650-02300
2006-2011 Toyota Yaris - (With ABS) 89650-52120 / 52050
2006-2011 Toyota Yaris - (Non-ABS) 89650-52070 & 520140
2007-2009 Nissan Versa 28500-EM30A / 991-30303
2009-2012 Nissan Cube 28500-1FC0B / JL501-000932
2012-2014 Kia Soul B2563-99500 / 4PSG1312 / FPSG1312
2008-2011 Scion XD 89650-52A10
where about in Indiana are you?
Does the Nissan Versa use the same 3 bolt flange to mount the upper column tube to the aluminum motor/gear housing that the Vue uses? Would you happen to have a picture of the Versa flange? If it's not practical to improve my Vue sourced units self centering by substituting a Prius ECU, perhaps the Versa unit would allow me to reuse some of the mounting brackets I've made.
The Versa's 3 bolt flange bolt pattern is little smaller but looks like it can opened up little more to accept the Vue.
This is disgustingly informative. Thanks so much for the time posting this. On a side note, I've always liked the Falcons. In 68, for a short time before I joined the Navy, I had a '60, with the mightly 85 hp 144 cid six, and the ONE barrel tiny Holley WITH the glass float bowl, which I managed to drop and chip in what was about my 2nd or third carb rebuild. My Dad worked at NAPA then, in our small home town of then maybe 3500, and they had a new bowl......metal....in stock.
do you have a size comparison side by side of the prius and the Saturn or cobalt one for comparison?
Great information--thank you to waid and all the posters for this information. Does anyone know if the Yaris non ABS controller will work with a pulse generated speed signal? Will this ecu talk to Corolla column motors that have the later torque sensors? Thanks for any help.
I am using Yaris non-ABS ECU with Prius column. It will not work with any other column. I am using pulse generator for now and later will add pulse generator from the reluctor wheel on my Ford 8.8 which will gave me variable speed dependent assist.
Waid
I watch their installation video for A bodies and they used a 65 Barracuda - way to go early A's!
I've been working on the conversion to a spare steering column I have. I'm just about done, the only problem I ran into was getting the correct 2 plugs to run the power for the ECU. Everyone what's to sell the complete wiring harness, and I was hoping for just a pig tail. I can post some pic if people are interested.
The cheapest kit I found was around $1350, I'm going to end up having about $150 into it.
It has been a while since I posted on this forum. I am not making or selling anything. I have posted this on couple of other forums and this is not for everyone.
Some of you have manual steering and I though you might like to see how added electric assisted power steering in my 1964 Falcon. Some of you may have come across the Saturn Vue conversions but I think I have found even cheaper and better alternative with no caster issues!
My testing shows that most Japanese branded cars and SUV with electric steering works in Fail-Safe mode if the control unit (ECU) is disconnected from CAN BUS. The effort in Fail-Safe mode feels just right like my 2013 Honda Civic. Not too much and not too little. Just like Hydraulic Steering, if the Electric Assisted Steering completely fails, the steering is back to completely manual mode maintaining car control.
The biggest advantage of using EPS from Toyota, Nissan and Kia/Hyundai is that the EPS works in Fail-Safe. The ECU for the column is mounted remotely and cab be disconnected and removed. The EPS from Saturn Vue and Chevy Cobalt has the ECU that cannot be disconnected and must be de-soldered for remote mount. More importantly there is no Fail-Safe and a 3rd party eBay module is needed in order for it to work. Additionally , people have reported that with after market eBay module, the Saturn EPS does not self center the steering wheel coming out of a turn. You have to make constant corrections.
Below is the list of Car that I know of that has Fail-Safe Electric Steering. Only 3 wire connection. Ignition On, Power and Ground to the Steering ECU. That's it !
2012-2014 Kia Soul
ECU Part Numbers:
The output shaft on Toyota is little larger than the rest and therefore the Borgeson 312500, 11/16 36 X 3/4 smooth bore weldable coupling should fits nicely. This couple fits the others as well. The Kia EPS is the biggest and appears to be most heavy duty. The Prius & Corolla EPS are very easy to find at salvage yards so this is the best bet. I picked up these EPS for testing for $35 each at my local pic-a-part
Note: As with any modification, there are risks. This post is intended to show how I did my modification. Use it at your own risk!
Waid
Waid302 you sent me a like on EPAS a few weeks ,very informative ,I can't locate any units you have worked with but I have accwiard a unit from an HHR a GM product ,have you any experience w/ these units , I have the 57 dodge panel .Thank Marty
2012-2014 Kia Soul
ECU Part Numbers:
Waid
2012-2014 Kia Soul
ECU Part Numbers:
Waid
Wai
2012-2014 Kia Soul
ECU Part Numbers:
Waid
This is genius. Can you use a regular Mopar PS steering box with this set up to get power and a quick ratio?
This unit doesnt change the lock to lock ratio, it only provides electric power assist instead of using hydraulic power assist. This setup will not give you a quicker ratio with a mopar power steering box slaved in with it, only a faster 16.1 ratio manual mopar box will give you a faster ratio with it.
What it gives you is the ability to use the smaller manual steering box and still have power steering with it, and eliminate a power robbing hydraulic engine driven pump , hoses, and belt.
I think what he is getting at is the power box is a quicker ratio than a manual box. I'm not positive on that, bit I thonk that's where he was going.
Knowing that, you should be able to do this mood with a power box. I'm gonna get a Corolla unit here shortly and try it.
Oh ok, so get a power box just for its ratio and use it like a manual box with no hydraulics hooked to it. I think you can now buy brand new 16.1 manual boxes though.
