The EMD Lifter is what is doing it. Mine did the same thing. See Post #32
MadDart - what do you suggest to remedy this ?
should i change to a different weight oil ? will synthetic help ?
hi volume pump or hi pressure pump ?
Before you start blaming it on parts, look at your oil.
You are running 20w/50 VRI.
Look at the viscosity index of that oil.
At 212 degrees F/ 100C it's at 20.5
At 104 defrees F/ 40C it's at 181.8
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1496497
20w/50 is going to act like that. It's going to jump up in thickness/viscosity at low temp/ cold start and go down to around 10psi per 1000rpm at running temp, because it's engineered to protect parts under heavy use and this is consequential.
Listen to your engine builder. Every engine is different. If you were running 10w/30 or something lighter, you may have some concern on good seal on moving parts with tolerances, but the numbers you are seeing in oil pressure drop are normal for an eccentric viscosity index oil like that.
Its not the bearings or the filter, Its the Lifters. If you want to solve it, change them out for the Howards EDM's and it will not have low oil pressure any more.
big shout out to mike @MRL I had a lengthy conversation with him on the issue, its definitely the lunati Lifter, their EDM style lifter is not a good fit for a higher lift cam. We went thru specs on the howard EDM's but my pushrods will not work since the howards sit a little taller. I just replaced the rocker adjusters and pushrods with custom length smith bros pushrods 2 weeks ago, I wish I addressed this sooner, for now I may just deal with issue until the end of the season then tear it down and replace the lifters, I will check with smith bros maybe I can send them back and have them shortened if I go with the Howards or look at alternative lifters.
I really wish Mike from MRL was closer to me and built our stroker!!
you are right on crackedback, originally had the 1068 on it, switched over to the 1085 witch is a little shorter, I have a 51515 on the shelf but I don't think it will fit, I had a tough time getting the 1068 off with the TTi's, things are so tight on this, the reason why I went to the 1085, we have TTI step headers with a canton billet oil filter adaptor plate.
Yup, I ran 20/50 Valvoline in my Swinger. Had 410 stroker in it and I used the EMD Solid lifers from Johnson. I also had Oil thru manton push rods to keep pressurized oil on the ball and cup. My oil pressure was low like yours until I wicked it up. I had like 10-12 PSI at Idle and around 45-50 PSI driving around. Get on it and it would go 65PSI. Cold it would hit 60 PSI at Idle and after it warmed up it would go to 10-12 Psi again at Idle.
