#MadMax
Hi I have a almost complete 440 steel crank engine and has hp rods. The block is a standard bore block 4.32 bore size and heads are stock 346 casting. The engine is disassembled for inspection and has grease and all the cylinders and crank bearing journals and no VIN numbers on the Block. Engine can be put back together with no machine work at all. I am asking $2000. I also trade depending on what it is and if I can use it.
My location is Collins Ohio 44826 I live 5 minutes from the Norwalk Ohio NHRA drag strip summit racing drag strip for anybody who goes to the drag strip racing that is interested in the engine.
If you have any questions please feel free to contact me. Thanks Duane
