69 M code Cuda resto and repair
Finally sprayed the epoxy primer… feels like I’m finally getting somewhere
Man you got something there ...this is the epitome of mopar A body $$$$
Looks great. I can't imagine the time you spent cleaning the bottom of the car. What did you use to clean it, a needle scaler? Your epoxy looks real close to the color of the factory dip primer too.
:thumbsup:
:thumbsup:
I have lots of time into this…first I was only going to degrease it and leave it…then it had some surface rust on couple edges and I was going to do some touch ups….then I said well I’m into it this far I might as well repaint the whole bottom..
I wired wheeled the whole bottom with a drill…then epoxy..
Then topcoat it with 3 coats dip color paint
Beautiful. How did you strip and clean the underside?
I mostly cleaned it with Mothers all purpose cleaner..scrubbed and scrubbed…then wired wheeled it inch by inch…I took a kids swimming pool and hose into garage sprayed car let it go into pool and dragged it out to empty it …haha…no kidding…I wasn’t planning on redoing anything with the car except going through driveline …and here I am
Final wet sanding…body and parts. Painted a couple parts and running out of room to put things…hung some parts off my other car
Bottom is all bagged up ….decided to freshen up the bottom of rockers stripes will cover paint line…spraying this weekend
My red stripes..dad put on in 1969. Leaving them because they will not come off easily
I know this story all too well. You were lucky enough to have the tools, time, & knowledge. Mine has taken me years.
Yours is Looking fantastic.
