Yes you can use an HEI module, if its a good one, and if you can keep it relatively cool.
Same as the Chrysler ECU, make sure you can obtain a backup for the one you chose. A lot of junk out there these days.
HEI controls the current to the coil. So no ballast resistor is used at all.
