Here's what I have behind my 408 stroker.Single disc or dual disc?
Organic, ceramic or Kevlar?
Any brands better than others?
Looking to replace clutch 71 Demon 340
Appreciate any input. Thanks.
A friend put one of those in his camaro. Yep, on or off. Pain in the azz because there is no feathering. It's a racing/stock car thing. I have a standard B&B style in my 66. It works well and has some feel. I am pretty easy on it though.I am currently removing a McLeod RXT dual disc ceramic diaphragm clutch from my Dart. I was talked into this clutch in 2018 when I didn't know a great deal about clutches. I can't stand it, there is no modulation, it is like an on-off switch, when it bites there is no forgiveness. These are a known parts killer. In addition, I am not a diaphragm pressure plate fan, too soft for my taste.
I am replacing this with a McLeod, Borg Beck and Long style pressure plate with a 10.95" organic disc with a flat plate carrier and no marcel. This should be less grabby and violent, while providing clean high rpm shifts.
My choices are not likely to reflect the masses here, trend seems to be soft pedal diaphragm clutches these days, however having run one, I wouldn't do it again.
There are some guys on here that know a lot about clutches, do your homework carefully.
69 Swinger, W2 408 with tunnel ram.
Have one in my 95 z28( I know, yuck right?). Sucks on the street. Custom made by Milwaukee clutch, in/out, grabs hard and harder the hotter it gets.I am currently removing a McLeod RXT dual disc ceramic diaphragm clutch from my Dart. I was talked into this clutch in 2018 when I didn't know a great deal about clutches. I can't stand it, there is no modulation, it is like an on-off switch, when it bites there is no forgiveness. These are a known parts killer. In addition, I am not a diaphragm pressure plate fan, too soft for my taste.
