Disc Brake Steering Knuckle Bolts
mopardude62
Missouri
I need the two bolts that hold the lower ball joint to the steering knuckle. I have a 1967 Barracuda that I have converted to disc brakes from a 1974 Duster. If anyone has a pair of these bolts including the nuts, please PM me! Thank you!
You can use grade 8 bolts from the hardware store if you're not looking for originality. Might have to check the clearance on the head of the bolt, but its been done by other members here.
