front disc conversion
montgomery county pa
have a 65 cuda v8 manual breaks on all 4 want to convert to manual disk what parts do i need or from what donor car but rather buy new but tryin to keep cost down
You need:
Large ball joint upper control arms (or ball joint sleeves from Dr. Diff)
73+ spindles, can be A body or F/M/J body
Caliper brackets for 10.87 or 11.75" rotors
Rotors, 10.87 or 11.75
Calipers
disk/drum master cylinder
disk/drum distribution block/combo valve
You can get the spindles, caliper brackets, calipers and even rotors from a F/M/J body car, ie, Diplomat, 5th Ave, New Yorker etc all the way up to 1989, so those are usually available in the local yard. LBJ UCA's are harder to find as you can only get them from '73-'76 a bodies, but on the cheap you can buy a set of adapter sleeves from Dr. Diff.
Dr. Diff also now sells the 11.75" caliper brackets, which allow for the larger 11.75" rotors to be run (from Cordoba's, Volare's, Fury's etc) with the same stock calipers. Nice upgrade in stopping power, but you also need 15" rims to clear them.
Master cylinder, rotors, calipers, and rubber or braided brake lines are all best purchased new, the core charge usually isn't even enough to warrant pulling the used stuff from the yard.
There are a TON of threads on this swap already if you do a search.
