Front End Alignment Los Angeles Area?
Bossanova5
Active Member
Los Angeles
Rebuilding the front end on a 65 Valiant and need to have it aligned.
Can't seem to find anyone who works on these anymore.
Does anyone know a really good front-end alignment shop in the Los Angeles Area that doesn't overcharge for alignments on these cars?
Thanks
Overcharge is subjective. $100-150. is about the going rate for a Thrust angle alignment.
Check 4x4 shops for recomendations on who is in your area.
Marlo's Frame & Alignment, Van Nuys. Marlin’s did all the alignments for Restorations by Julius when he had his Mopar restoration shop in LA.
Cars Automotive & Muffler, Redondo Beach
Steve at Johnson Alignment, Torrance
Simpson Frame and Alignment, Hollywood on Gower.
Tyerman's Automotive, Burbank
I called the following:
1) Simpson Frame- the guy wants $450 for the front-end alignment. $175 per hour. 2 1/2 hours for a front alignment seems really excessive. Can't imagine it takes 2 1/2 hours for an alignment. Being that the last guy (Unfortunately, he went out of business) who aligned it took him under 30 minutes.
2) Marlo-wants $200 for the alignment
3) Johnson- wants $100 for the alignment
4) Tyerman - $150
5) Cars Automotive & Muffler $150-200
Thanks for the information.
1) Simpson Frame- the guy wants $450 for the front-end alignment. $175 per hour. 2 1/2 hours for a front alignment seems really excessive. Can't imagine it takes 2 1/2 hours for an alignment. Being that the last guy (Unfortunately, he went out of business) who aligned it took it him under 30 minutes.
4) Tyerman - $150
Thanks for the feedback.
Simpson is in Hollywood and been there for a looong time. Seems they are pretty proud of themselves. Pass on that for what you are doing.
Distance would be a factor on the others from you.
Tyerman's has been there forever and i frequently see old stuff in their lot. I had them do a car 20 some odd years ago and was pleased with the price/results at the time.
@Bossanova5
Is this your Valiant?
When I left the underside of the alignment rack people were having conniptions because prices on a thrust alignment was going from $50 to $60.
I paid $125 to have my 12, 1/2 ton 2wd done, I then bought a pair of Michelin tires for the front and the inner edges of both front tires were shot in less than 15k miles.not happy.
I did recently check the parts and all ball joints tie rods etc are still tight, no wear
