chrgdrt
What glue/ adhesive are you guys using to secure the well liner to the rear seat support? 67 barracuda if that matters.
thanks,
Gary
thanks,
Gary
I believe this is the oneWish I remembered the product. But IIRC it was a yellow color and I think it was basic interior adhesive.
The yellow 3M dries quick! Glad you found something, though!I ended up using a loctite 300 heavy spray adhesive but a brush on would’ve been easier as I had to mask the area to prevent any overspray.
I never had any luck with the weather strip adhesive, seems I put it on then you have wait 5 or 10 minutes so I go do something else and then forget to check back before it dries.
thanks for the advice
