High end audio alternator
Boduke
Mass
Anyone running high end audio? Im not talking competition grade but at least 1000w
Whats the alternator of choice . Currently my 60 amp stock is fine at cruise but i need more juice at idle
Choices are denso/gm/tuff stuff mopar. Most of what ive read so far are inconclusive. Also. Im not upgrading my whole harness. Ammeter and bulkead connections have been addressed
Right now denso looks most visually appealing.
Thanks in advance
A 1000w is about 75 amps so about (75+60) 135 amp alternator.
Look for ones with good output at idle.
Not specifically for audio, but I'm using a stock '89 318 truck alternator. I believe it's 100 amp.
Make sure you use the correct gauge cable for both positive AND negative from the alternator, feed your amps through relays hooked directly to a 12V+ distribution lug that doesn't go through any bulkhead connector, and use a big, AGM battery, which acts like a massive capacitor to power through high current draw bass hits.
The Odyssey battery I'm using has a 5000 amp dead short rating. It will heat a short-circuited wrist watch to 400 degrees in a fraction of a second....really.
