Installing a petronix unit
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
halifaxhops submitted a new Article:
Installing a petronix unit is simple this is a slant but the 8 is the same.
Remove the points and condenser and primarly lead, can be done installed, I took the breaker plate out for better pictures.
Clean area
Install positioner plate for the pick up. Lock tight the screw is recomended....
Read more about this article here...
I used a system like this WAY back in the late 80s. It's only issue was it used a propriety rotor. I like this one, you could go back to points on the side of the road if you had to.
