Mopardude
What are people using for an accellerator cable bracket on the mighty demon carbs? My bracket I was using from Bouchillion performance I can not reuse because of the curved base of the carb it has no way of supporting itself so the first time you press the pedal down it just pivots forward. I can not use a stock bracket because I have an airgap intake plus if I did modify the stock bracket to fit it probably wouldn't be high enough anyways. Any suggestions?
