The original question was deleted because I can’t delete the thread. Just got tired of all the unnecessary negativity. Thanks to those who replied below with helpful info.
From what I remember , you said it is a 360. The pics portrayed an LA engine. It would be rare for someone to put LA heads on a magnum engine but it is possible. Make sure you can add a mechanical pump before making the plans as magnum engines in their stock form do not have the provision for mechanical pumps.The original question was deleted because I can’t delete the thread. Just got tired of all the unnecessary negativity. Thanks to those who replied below with helpful info.
I looked up the casting numbers and it is a 1977 360 LA. It has a cover over where the mechanical pump was removed. I've decided to hold off on making any changes until I do my homework on all the EFI options. Thanks.From what I remember , you said it is a 360. The pics portrayed an LA engine. It would be rare for someone to put LA heads on a magnum engine but it is possible. Make sure you can add a mechanical pump before making the plans as magnum engines in their stock form do not have the provision for mechanical pumps.
The way this reads, it sounds like you think all 360s are magnumsFrom what I remember , you said it is a 360. The pics portrayed an LA engine. It would be rare for someone to put LA heads on a magnum engine but it is possible. Make sure you can add a mechanical pump before making the plans as magnum engines in their stock form do not have the provision for mechanical pumps.
No I do not think that and I'm not sure how you get that out of my statement. Because he said he was a newbie, I thought he should know the difference even though a magnum block can be made to use a mechanical pump with the correct camshaft and an La timing cover.The way this reads, it sounds like you think all 360s are magnums
That can't be right, can it?
Now I see it. Ya Its a little out of context with the original post removed too.The way this reads, it sounds like you think all 360s are magnums
