[WANTED] Non A/C 67+ defroster hoses (ducts) & 67 Barracuda d/s manual lock rod
Mattax
Just the facts, ma'am
Phila. Pa
Update: Looking for '67 up non-A/C defroster hoses in better condition than mine.
Doesn't have to be perfect. I can wrap a hole in gaffers tape or similar. I'll do that to mine but would prefer to start with nicer ones if I can.
Here's mine.
Found! 1967 Two door, Manual door lock rod and whatever may connect it to the latch mechanism. FOUND!
Orange items in illustration.
I think I have a rod that looks like the illustration but could not see how it attached tothe mechanism. Don't even know if its the correct rod.
Matt, I have a complete 67 notch door. Can't remember if ds or ps.
Well, when you dig the car stuff out of winter hibernation, I might still be looking. This one is a mystery to me that I've just ignored for a long time. When I clear some space I'll take the inside panel off both sides and maybe I can figure out what it ought to be. But if someone already knows and has the part(s) that will be great.
That rod snaps into a plastic bushing.
I have those parts.
That would be great.
I bought a new plastic clip 25 years ago, which I still have, but it must be for another model or the right side.
Matt, check pic, the red plastic piece in door latch I believe is one piece you need.
Yes that looks right.
I'll go down to the garage and take a photo of the one I have. It has a hook on it. Someone can use it if we can identify it.
Maybe its time to take another look at the other mysery in the front door - there's play when the window is rolled up.
Barracudakid should have it. I don't know if the same bushing was used left and right.
Way different than the two I have. These are almost certainly one side only.
Hey Matt, just checked and my door is pass side sorry.
Thanks for looking Steve. Barracuakid had it and the grommet/bushing.
The only item here still looking for is a non a/c passenger side defroster hose. That's the shorter one (21" according toth ebook) with 2" inlet
Update. Turns out the one defrost hose was for early A. Still looking for both hoses if in decent condition.
