O-ring for 727 dipstick tube?
69_340_GTS
Torrington, CT
Anyone know exactly what size, or what the generic o-ring part number is, for the dipstick tube on a 727? Thanks!
Aren't they flat on the side?
I would take the tube to a "real" parts store like NAPA and have them dig through their jobber drawers for one that is the correct diameter and cross section. You may get lucky buying a $10 kit at harbor freight but the cross section on those are kinda small if I recall. The flat shape is most likely deformation on an old ring and probably the reason they start leaking.
The newer ones are a sleeve, I forget if they fit the old transmissions/ dipsticks.
I got a decent sized assortment of O-Rings at HF several years ago. It has come in very handy on many occasions. Check it out.
.750 x .100, Pioneer p/n 762001-10. I get from most of my o-rings from my local Parker Hydraulics shop, cheap.
