Dan the man
I believe that you have a lot of experience with engine building, what size rings do you like*cough* Mahle powerpak *cough*
I've learned plenty about car buying. Got 3 to go look at. I just knew that if I waited long enough that the prices would come down and that's what happened.you haven't learnt how to buy a car yet though......![]()
I'm gonna have to respectfully disagree with the first sentence and with the last sentence.I’ll tell you Dan, the biggest issue I have with any KB piston is the garbage 5/64 ring pack.
I can’t think of a single scenario where those thick tractor rings would be better and I can’t think of one.
In my world any piston made today would have no thicker ring than .043 and it could be made even more simple if they just used a 1 mm ring.
Other than it’s about all you can get IMO a 1/16 ring pack is obsolete as well.
Thick rings eat power, cause more heat and don’t seal worth a crap.
more than most, less than a lot of others. it's not about what i like. it's about what is correct for the application, what fits the budget, the overall build plan and availability.I believe that you have a lot of experience with engine building, what size rings do you like
Well, IMHO you both have points. The 5/64" ring sets have been in use for decades now and are well proven. If they work for you and you are happy with using them, have at it and carry on.I'm gonna have to respectfully disagree with the first sentence and with the last sentence.
Here's my experience, with that so-called, "garbage 5/64 ring-pack"
As to power;
My 367 has gone 93 in Eighth, at 3457 pounds, at 900 ft elevation, which the Wallace estimates is 430 hp.
As to heat:
and she runs the exact same temperature, no matter how many runs I make back-to back.
as to Not sealing
On the day I put them in, I couldn't measure any leakdown at all. In one particular combo, the pressure went to 195psi.
I've got over 100,000 miles on those rings now.
Bonus
I got up to 32 mpg on a certain day trip on those rings.
They may be garbage, IDK.
But I'd buy them again, without even thinking about it.
Finding the appropriate pistons and rings for the intended use and budget is where the bannana peel hits the sidewalk. Sometimes availability trips us up and usually the budget whacks us upside the head.more than most, less than a lot of others. it's not about what i like. it's about what is correct for the application, what fits the budget, the overall build plan and availability.
i like light, forged pistons with modern, thin ring packs. but that might not be what's on the menu, so some cast iron tractor rings will have to suffice. and they'll be fine for what ever it is that's being built.
GTFOI've learned plenty about car buying. Got 3 to go look at. I just knew that if I waited long enough that the prices would come down and that's what happened.
Depends, and that is not the ones DJT gets at Walmart. Look around at say Summit for pistons with the top design and compression height in the bore size you need. 1/16" are fairly common if you look.*cough* Mahle powerpak *cough*
Modern technology and materials has enabled the ring widths to be reduced for lower friction in the engine which equates to more power and fuel economy. The General went to 1.5mm rings on their LS engines which is very close to 1/16" ring width. NASCAR is down to 0.5mm compression rings. That is about 0.020" ring width. That is almost like using oil ring rails as compression rings. Those teams are chasing every 1/2HP everywhere they can find it.
For a new build looking to modern rings could be of benefit. Some aftermarket LS off the shelf pistons are now machined for 1.2mm, 1.2mm and 3mm ring sets. If you find a piston with the chemistry, piston top design and compression height you desire, use it and the rings it is machined for. 1/16" or 1.5mm are likely the same cost as 5/64". Also consider ring weight as a factor when racing. As you get progressively narrower rings the price seems to get progressively higher as you get narrower than 1/16".
For my Ford 289 I found pistons that take 1.2mm, 1.2mm, 3.0mm rings. Total Seal makes a zero gap top set that will work. The issue is today's cost delivered to Canada for pistons and rings is about $1700 CDN. But then I do not foresee ever having to air out this engine again.
Yes 1/16" are falling into the obsolete bin.I’ll tell you Dan, the biggest issue I have with any KB piston is the garbage 5/64 ring pack.
I highly doubt that Dan will put any of this information to any practical use.I expect Dan will be on a fairly tight budget. His asking questions here is good as he can bounce ideas around to find out what he should be looking to or for and what to avoid. Y
That is the cost of the pistons and rings through Summit. Remember we get hosed for the $ exchange at 1.4 these days and our prime peckerhead spashing money around to appear as a world savior is only getting us deeper in debt which eventually sink our $ more. I already have most of the stuff for the heads, valves, screwin 7/16" rocker arm studs, roller rockers, guide plates and hardened push rods. That is up in the $1200 range alone, and then the guides and machine work will be up there also. So rebuilding my 289 will be close to $5000 CDN by the time I am done. Yup, costs us a fortune. Housing is pretty expensive with having to dig a basement and pour concrete walls to 6 feet in the ground to get below where the frost gets over winter.Holy crap!! 1700 CDN? Check with Summit. They sell TS rings under the Summit brand and I can’t say for sure but I’d be surprised if you can’t find that ring for half of that money.
The biggest reason 5/64 rings are still used is the “market” thinks a thick ring seals better (it doesn’t regardless of who thinks they do) and the piston manufacturers aren’t willing to change up the tooling.
They shouldn’t make pistons that take those big assed, clunky rings.
That is up to him. I have generally pretty good patience. If he does apply what he can learn here, he should end up with a lot of mechanical knowledge and a car that runs well.I highly doubt that Dan will put any of this information to any practical use.
dan's so cheap he could squeeze a nickle and get six pennies.I expect Dan will be on a fairly tight budget. His asking questions here is good as he can bounce ideas around to find out what he should be looking to or for and what to avoid. Young people need help to avoid those manure piles some of us have stepped or fallen into.
And what do you mean by this??GTFO
An F1 piston, one stinking piston costs $50,000. I do not own a vehicle worth that much, and do not envision ever spending that on a vehicle if I could afford it.The other thing not mentioned in this thread is that some high performance and almost all race engines at a simi pro and pro level are having pistons custom made to their design specs. Which is about 500 give or take per piston. Don’t forget rods, cams, and everything else. So comparing a racing engine and a basic ***** of the shelf parts street engine is apples and oranges. A street engine is made to last say 100,000 miles. Depending on the end use of a race engines about 15-20 hours. Just watching Kenny Wallace talk about his dirt car, it’s 30 grand for a rebuild. Way way outside of your pocket book Dan the (No Car) Man…
Buy a car. Prices never came down. Good cars bring good money! Junk cars prettied up are still there for less and then total junk. Good Cars are still sold at above what they were worth years ago.I highly doubt that Dan will put any of this information to any practical use.
Believe it or not I did a Google search on it before junkyardhero replied.GTFO means: Kind sir, might you please depart the premises?
Pweeeeeeeeeeeeesh
Not to beat a dead horse, but that can also be solved with a google search my dude.
I was surprised too, the 1976 dart sport was first listed at $29,000 and now it's $25,000. Now, just going by the photos it's a great looking car. But time will tellBuy a car. Prices never came down. Good cars bring good money! Junk cars prettied up are still there for less and then total junk. Good Cars are still sold at above what they were worth years ago.
You will never know! You are a bench racer, dreamer who is just dreaming, collecting pictures, talking crap. And dreaming up excuses after excuses of why you did not buy. Carry on. Your screen name should be changed to Ambein...........I was surprised too, the 1976 dart sport was first listed at $29,000 and now it's $25,000. Now, just going by the photos it's a great looking car. But time will tell
By me waiting a few days, I'm saving 4 grand. I'm probably a better buyer than you are because I don't just jump on the first thing I see. For all I know you may be talking crap too as you've never posted a picture of your car. 340six, yeah rightYou will never know! You are a bench racer, dreamer who is just dreaming, collecting pictures, talking crap. And dreaming up excuses after excuses of why you did not buy. Carry on. Your screen name should be changed to Ambein...........
