6T9 GTS
Car: '69 Dart GTS
Weight: 3600 w/ me in it
Gear ratio: 3.23 Posi
Tire Diameter: 225/75/14 all around
Rpm through trap: 4300
MPH: 96
E.T.: 14.55/2.2 60 ft.
C.I.D.: 344.5
Heads: '69 340 X head
Head Work: stock
Valve size: stock 2.02 int. 1.88 ext.
Cam: Racer Brown
Cam Specs: .460/.460 .264/.264 .226@ .050
Plugs: Champion N9YC
Intake: Edelbrock RPM Air-Gap
Carb: Edelbrock 750 manuel choke with electronic conversion
Pistons: TRW forged .030
Comp. Ratio: 10.5:1
Trans.: 727
Trans. mods: shift kit and heavy duty bands
Convertor: stock
Convertor stall: around 1100
Stock driveshaft
Rear end: Chrysler 8 3/4 with 3.23 posi
Timing: 36 degrees total @ 1500
Getting ready to build another motor this spring 416 stroker with solid roller and alot of compression and a set of Indy heads.
MPH: 96
C.I.D.: 344.5
Head Work: stock
Cam: Racer Brown
Comp. Ratio: 10.5:1
Trans.: 727
Convertor: stock
Stock driveshaft
