jrlegacy23
68 Barracuda
Have you looked at these:
http://www.justsuspension.com/pro-touring-torsion-bars.html
GoldOne Just came across your build. These are a bit late for you to use but maybe someone else having a wheel fitment issue might be interested. Here are a couple links;
http://www.jegs.com/i/Percys/760/01201/10002/-1
http://autowaretech.com/mountmate/
Nice job on your build!
Found the PST 1.03" on ebay for $219 free shipping.
http://www.ebay.com/itm/1-03-Torsio...:Dodge|Model:Dart&hash=item1c2ac7e151&vxp=mtr
I've settled on 49 5/8" planned for the disc to disc diff width....
The 8.8 I'll be using has a 2" pinion offset to the passenger side. Since these cars come with a similar offset (something like 1 3/4") I'll likely take the same off each side. The 8.8 is 59.5" disc to disc, so that will mean 4 15/16" off each side. The minimum cutoff according to Dutchman Axles is 3.5" so I should be fine.
Found the PST 1.03" on ebay for $219 free shipping.QUOTE]
My mistake, the price is for 2. That's the best I've seen.
What's your overall axle flange to flange measured at?
I've got too many scraps of papar floating around and CRS so I decided to use FABO for keeping track of the numbers. Kinda handy to get at it with the iphone when not at home.
I've also become very handy with the EDIT button while its available
I think your tire is taller (I'm at 27") and with your coilovers you'll be lower so I imagine you will have to chop out the outer fender wells.
Just out of curiousity, do you have your tire's section width and height handy?
I don't know how close these cars are in the frame and quarter dimensions so I'll throw these out there.
frame to frame (wheel side) - 38 7/8"
quarter lip (inside) to lip - 67 3/4"
lip to frame - 14.5"
(discussion on measuring for backspace: http://www.forabodiesonly.com/mopar/showthread.php?t=220183)
If you haven't bought t-bars yet, with being a member here you get 10% off purchases of $200 or more so the 1.03" bars would actually be $197.10 and free shipping. Just something to consider.
Thanks
