Small Block Head Flow Chart
Did you do any chamber work to go along with those larger valves?
I will post of a picture of the eddy head as the SM are bolted onto a block at this time....IMM did the work So i would assume that the chamber was reworked for the larger valve.
OOTB Ede RPM assembled head #60779.
4.00” bore, 28”, no tube on ex-
Lift———in/ex
.100—— 64/49
.200——126/97
.300——185/133
.400——227/156
.500——250/166
.600——253/169
Cast SM flowed by @pittsburghracer
Lift—- in/ex
.100— 55/37
.200—131/100
.300—185/142
.400—235/164
.500—240/176
.600—246/180
.700— 259/185
CNC’d SM head-
OOTB vs valve job with back cut valve, and minor blend-
28” test pressure, 4” bore:
A-OOTB
B-Valve job
Intake ports:
Lift———A/B
.100— 64/67
.200—126/132
.300—166/191
.400—206/232
.500—242/262
.600—271/275
.700—284/281
Exhaust ports:
Lift—— A/B
.100— 49/55
.200— 95/102
.300—132/137
.400—163/170
.500—179/188
.600—187/192
.700—190/194
PHR, so can we assume an untouched CNCed head would flow 250 or so? Thanks. Kim
See the chart on page 1. I think the cnc head is there.
As of today the chart is up to date with every post that had flow data.
I had to give up on graphing all the numbers, too many to be manageable, but if you open the chart on a computer it's easier to see all the data
The “OOTB” test(coulumn A) is just as it came ootb.
That is the CNC ported head.
The OOTB unported head is in the 250 range(on my bench).
And probably a little turbulent too. At least it was on mine at .600-.700.
Because @yellow rose asked...
My (Long Stalled) W5 project. Ti 2.08/1.60 valves.
Heads ported by Brett Miller (Thank you) flower on a 4.125 bore.
Re flow checked by ElSasser Racing Engines on a 4.03 bore. (Which is closer to what I’ll actually have unless Santa Clause drops off a Ritter or MP race block.)
Brett took them until one of the ports gave up the ghost and broke through. Epoxy was used in 1 port. No sense in going any more forward.
Looking to use my Ultradyne NF64/ F69 SFT in a stroker.
I've added a second page to the chart with the heads sorted by type, it was getting fairly long and required a bunch of scrolling to the side to see everything.
Looking for feedback one vs the other, or any changes that would help with making it easier to view and compare.
Again, best viewed on a PC, phone screens with always be a limit, but I know lots of people use their phone first, so feedback based on mobile viewing is appreciated too.
Great job Turbo! I also like the second chart with the heads sorted by type, makes it a bit easier to navigate around.
You always will have to scroll when you want to compare heads...
:thumbsup:
Ultradyne NF lobe (Harolds) NF64/NF/69
The cam card is not in front of me, so, IIRC, .620/.640 lift.
The heads actually have my W2 rockers on top.
I’d like to get a Jesel set up in a 1.6 rocker.
Got my w5s back today, was hoping for better flow numbers.
Do you know in what bore size the head tested at?
Was there any mention of the port going turbulent?
Did the head require epoxy?
Did you mention your valve sizes?
I wouldn’t be to upset. That’s enough flow right there for some serious HP. Plus the head ports are still moving some pretty good air past the peak. If you were so inclined to continue lifting the valve, you will still be making more power.
The only 2 drawbacks to the W5 head is the possible poor casting ether turning the head into water sprinklers (leaking) and/or not being able to be ported out to some of the reported superb flow numbers that have been done. Then the expensive rocker arm set up even though it is seriously superior to other offerings, which has excellent dividends, it’s just pricey as I said. Though if it is a race car, it would be worth it. Street car? Ehhhh, owner’s call.
Again, I understand being disappointed with the flow results but they show well enough for some *** kickin.
They sure are pretty! It's fun to look down the intake ports and not have to look past the pushrod pinch!
I agree and that’s what makes these heads (W2/5) worth it. A larger unobstructed port window (Or a door to allow more people in) than the LA head and it’s replacements.
Like Swedish Viking, I was hoping for more cfm to help out a large(r) cubic inch engine.
The flowing was done with a bore of 4,10 and with 2" exhaustpipe.
Well we will see what kind of cam it gets. Roller or flat.
I have a set of Eddy Magnum heads that were ported looks like 10 yrs ago...4 files...stock intake...stock exhaust and ported intake and ported exhaust...
These were done in Carson City NV.
  • eddy mag ex.pdf
  • eddy mag intake.pdf
  • eddy ported mag exh.pdf
  • eddy Ported mag intake.pdf
