Spare tire hold down bracket/gas tank J bolt ears?
H22A4
Does anyone read this?
YVR
It's the metal piece on the floor of the spare tire well which secures the bolt for the bottom of the jack stand and also doubles holding in the J bolts on the bottom which keep the back end of the gas tank supported. Is this piece reproduced by any of the repo shops?
I don't believe that piece is repoped. Same for 68 up. Should be ample good used avail'
amd did make one....i had one listed on here,sold it on cl tho.
a good used one from 68=76 will work but they can be hard to find.
AMD does repop them, but they only sell it as a pre-welded part on a full trunk floor. I called them direct about a month ago to see if they will sell one separate. No go. My shop fabricator took the best parts of two I gave him and he did a great job putting one together.
Dennis
