I'm using an accessory drive kit from March Performance that mounts the alternator and AC compressor up high - so frame rail contact is not an issue. http://marchperf.com/styletrack_hemi.htmlI really wish I knew how to do this runout check. I'm prolly gonna have to find someone loclly here to help me do mine with the quicktime bellhousing.
Keep up the great work.
Oh any pictures of the alternator area where it hits the frame rail?
Riddler
The documentation and build are both outstanding! Great help for lotsa members, and a great read!! Thanks!
Either, I'd really like to see the differences between the two. If need be I'll find myself a Jeep alternator.
Riddler
Since I want to run all the stock gauges, I needed a spot to install the stock water temp sensor. The top front of the water pump housing looked like the easiest spot.
I'm confused....Why didn't you just remove the existing temp switch and use your adapter bung with the old sensor in the original location?............... That's what I did
Because the FAST Fuel Injection system needs the stock water temp sender as an input.
How'd you go with your dipstick? Did you send it back to Milodon?
Mine arrived via priority mail last week - they shortened it around 3/4". Ill let you know how it fits on Sat...
Something else I'll need to check also.....
I have a factory 6.1 flywheel off my crate motor you can have for postage costs - probably about $40 canadian from me to you.......IF you get stuck.
Real Wing - The modified dipstick ended up fitting a peach - the top bracket clips onto the valve cover stud.
