racerjoe
The perfect solution to the kickdown problem is a manual transmission...lolNothing just yet. Driving normal, it's pretty good. It's just when you roll into the throttle, at about 1/4 pedal, it'll give a flash of a kickdown and then resume to normal.. floor it and it doesn't seem to do it. Nick is wondering if there's something going on with the valve body because everything else is fresh. I'm still playing with different length levers to see if that makes any difference. The Bouchillion lever is much shorter than stock and that's what I had on there at first. I've been trying a longer lever for a few days now and it seems better but throw ratios are too different to work right. If I set it like it should be ..tv fully open at wot, the lever still has considerable pull on it at idle. Shorter lever and it kicks down easier yet or never shifts into 3rd. On the way home yesterday, I think it may have been getting better tho. It's just weird
