Figured it was time to make my life easier. The numbers matching 727 is next in line for the H1 Demon restoration.
I agree with the "no room" part (we've all got that)......But, based on some of the things you've tackled, I don't think "know how" is a problem.Well done Troy! I have a spare stand, but dont have the room...or know how lol.
The tabs near the tail housing are the same, but at the bellhousing, the small block tabs are wider by about 2 inches. The dimension front to rear is the same between the two.I've never thought about it until now, but I wonder if the tabs on the transmission that you used for the fixture attaching points are in the same place on both big and small block 727's? I would think that they would be since the cases between the 2 are the same, aft of the bellhousing.
Great job on the fixture!
