[SOLD] W2 heads and intake
darto
Petaluma Ca
W2 heads 3870810 castings
One head has had a repair as shown in pictures. Didn’t hurt performance.
Head that was repaired was pressure tested by a machine shop and came back good. Have paperwork.
Has dual valve springs
3 15/16 bolt pattern
Removed from running car on 4/9/21
includes an old Holley strip dominator intake.
$550 for heads and intake.
Located in 95403.
2 x $20 per head stripped in a USPS game box. Then the valves and spring in numbered bag in a medium USPS flat rate box.
I have also shipped intakes in the flat rate game box for $20.
Looks like you played the shipping lottery and won. 150lbs going from coast to coast was never going to be cheap.
How was the broken head "repaired"? Looks like putty or JB weld? Or was it actually furnace welded and machined?
Repair was welded. Didn’t know it was a repaired until I removed the heads.
yeah anything with weight will cost..I am guessing I pay 40 % sometimes of the cost of the item. I will admit I maybe doing something wrong :)
No, it was running fine when I removed the heads.
compression ratio was 10.5 to 1 with a Felpro 521SD head gasket
I’m going back to a stock, and my storage space is limited, that’s my reason for selling
