Where does this wire go?
64longroof
Kentucky
Looks like previous owner modified something behind the instrument cluster, adding a ring terminal to this wire, in foreground. Anyone have an idea where it should go? It is a wire original to the harness, a paler blue than the one you can see behind it with the wire bundle. Neither wire has a stripe.
Thanks
We have free wiring diagrams here for download if you do a search for them.
Guessing a 64 wagon of some kind since all that info faded out after it was typed or something:D
dose it have power ? earth? failing that try following it back through the different blocks see where it leads to
"Guessing a 64 wagon of some kind since all that info faded out after it was typed or something"
Yes, that's what happened................hey, its an A body dash, A body forum!
But seriously, thanks, I found the diagrams.
Makes me wonder, what do you color blind folks do when it comes to wiring??????
Diagrams from MyMopar:
http://www.mymopar.com/downloads/1964/64DartA.jpg
http://www.mymopar.com/downloads/1964/64DartB.jpg
What might make sense is this is the fuel gauge sender wire, and the original connector for the cluster is AFU. The fuel gauge I believe has a stud / nut for the sender wire, which normally jumpers over to the cluster connector.
You could find this out right quick by
1....checking this unknown for power
2...If not, then check resistance
3....Then access the kick panel connector for the rear harness and separate it, and re-check resistance. If it goes open, you have found it
Also check the cluster connector and see if the light blue at "J" going to the sender is out of there
We ask Del, (67Dart273) ^^^up there :D
LOL I ask the "King of Obsolete"
http://www.kingofobsolete.ca/King_today_webpage.htm
He says just use one color....."black" LOL
:angel12:
Of course it does. So does SNAFU, and RTFM
Read ..........The........F. F.......Fu.......FACTORY
Manual LOL
