Most of your noise will be coming from the door glass not sealing properly to the roof rail seals. You can adjust the door and quarter glass, but it can be a very tedious job and you can quickly make things worse if your not familiar with the process.
The window felts will not impact the noise that is getting into the car. If the vent window is not sealing properly, you may be getting some noise, but typically is more of a problem leaking water than noise. The mylar glass channel runs can lead to the door glass rattling and wind noise due to the seal falling apart.
All of the seals are available at this time with the exception of the mylar glass channel runs. Hopefully, the manufacturer will have them back available to the vendors by the end of July.
