fishy68
Tyr Fryr's Inc.
10-1/2" A-body bellhousing # 2892484 with dust cover. Has 2 thread holes stripped. I'm not a 4 spd. guy so I don't know if those holes are even used as I'm sure not all are used. I circled the holes with a marker so you can decide. $175
10-1/2" flywheel in real good condition. I was told the flywheel was off a 340 but I forgot to ask what year. It has some holes that look to be like balancing holes drilled in it but I looked through the Mopar chassis manual and the holes don't correlate to any balancing holes you drill for an externally balanced engine so I assume their just to balance it for an internally balanced engine?? You can see them in the last picture. The close up shot is to show there are no heat stress cracks. $50
All items can be picked up in central Illinois 45 miles n.e. of St. Louis or I can ship them at your expense.
