B&M has spoken:
Brad,
Yeah that is definitely on backwards.
John Couch
B&M RACING & PERFORMANCE PRODUCTS
9142 INDEPENDENCE AVENUE
CHATSWORTH, CA 91311 USA
T 818-882-6422 EXT 365
F 818-882-6694
[email protected]
Not getting any sleep last night paid off. Easy fix at this time. Thanks guys rayer:
The flex plate should be marked, "Engine side".
Bill S.
You can only install all 6 bolts when it is on correct because the bolts are offset. Therefore it is not possible to install it backwards.
News Flash! I drove over to http://www.mopacautosupply.com/index.html yesterday and talked with Chris Lunn, resedent Mopar expert that has a 69 Dart, LA 360, 727. Turns out my flexplate is on correct but, it is the wrong P/N flexplate. The one in my picture is for a externaly balanced engine. See the cut out. My engine is internal balanced and the flexplate has no cut out. The correct flexplate is stamped "Engine Side" as well. Looks like I have to change it out any way. FYI
