I did a search here for a 5.9 EFI Swap and what I saw did not answer what I wanted to know. I kept reading how much better it was to change to the EFI to a carb.
Here is what I need to know. What is involved in making the efi work in a 64 Valiant?
The Donor is a 96 Dodge Ram 1500 I can get everything I need to do the swap from the truck itself. So I know installing the engine is the easy part and there is a modification to the trans tunnel to fit the transmission.
What is needed to be done to wire up the computer and to have a running and driving car?
Please no post on how it will be easier to convert the EFI to carb.
Thanks
Thanks
