- Joined
- Apr 18, 2009
- Messages
- 4,310
- Reaction score
- 4,901
Some of ya might have been over to FBBO and seen my early b body build with a 5.7 hemi and 545rfe trans. Well I've been throughly dissapointed with mpg.....13.5. This was checked with a full tank, drove 70 miles a day for 3 days, all freeway and filled up again to check.
My combo is an 03' 5.7 hemi truck engine, 6.1 hemi injectors, cnc made adapters to clear the timing cover so I could use a car intake, TTI headders with their 2.5inch x-pipe exhaust, 742 sure grip center with 3.91's, and 275-60-15 rear tires (28 inches tall). It shifts through all gears and I can feel the tc lock up. The car weighs about 3600 lbs with me in it and a full tank. This is flippin' sad to say the least.
I called Chris at hotwireauto and he said that I need to move the o2 sensor to the passenger side from the drivers side and that my gears are to low, need to be 3.55's. Sorry, but I'm calling B.S. on both of those. I checked the o2 sensor and it was sooty and I cant figure out why. I have double checked the speedo against my wifes Iphone and it's on the money.
I will say the car moves with authority and will boil the tires if you look at the accelerator pedal wrong. So WTF!!!
