[SOLD] Comp 268H cam and lifter kit new
rmchrgr
Skate And Destroy
Stamford, CT
Comp Cams CL20-212-2 cam and lifter kit. This is the 268H cam for LA small block engines, 273-360. Good, mild street cam.
Specs as follows:
Hydraulic flat tappet CRS 268H-10
Basic Operating RPM Range 1,500-5,500
Int. Dur. @ .050" Lift - 218º
Ex. Dur. @ .050" Lift - 218º
268º Advertised Duration
.454" Valve Lift with Factory Rocker Arm Ratio
Lobe Separation (degrees) 110º
Comp 901-16 springs suggested but I believe you can use stock springs and other related parts and still be OK.
This is a brand-new-in-the-box kit that retails for over $215. $200 shipped. Parts are located in Huntington, NY 11743. PM with questions.
I can make someone a deal on the springs needed for this cam! Someone buy this!!
And I can STILL make someone a smoking deal on the springs AND retainers for this cam!! If you buy this cam from rmchrgr, I'll knock TEN BUCKS off my springs and retainers for you!
How long have you had this cam? Has it been on the shelf for a while?
Yeah, it does have the older packaging. I have had this cam since last year. Regardless, it is a BRAND NEW NEVER USED cam and lifter set.
As of today, I still have it.
