carbs, sb intake,accessories
dartsport74
lodi, california
Would like to clear some shelf space, all parts shipped frome 95242 or local pick up lodi or stockton CA
I have a holley 4 barrel worked well when removed 70$ obo Pending sale
original 2 barrel air cleaner assembly off 74 dartsport 318, 30$ obo
original 2 barrel carb from same car as air cleaner assembly, 20$ obo Pending
original carter thermo-quad carb off 75 360 originally 100$ obo
(sorry for any confusion on thermoquad, and thanks for those who helped me figure out what it really is)
If it is off a 1972 340 it should be 6138 or 6139 depending on automatic or manual trans....
Thanks. i know the block is a 72 340, but i will make sure to get numbers. I was told it was all original to the motor and the guy had the original water pump on motor so i took his word on everything being original on motor.
Also how do i go about looking up the part numbers to find out exactly what i have and what it came off of originally???
thanks robert
for the thermo quad so far the only numbers i could find are on the top by where the thermo quad is cast in carb those numbers are 6-2141 ill take the carb off and get the numbers off other side in the next day or so.
Robert
Check numbers on the front part of the ear of the passenger side front bolt hole. Maybe a 6xxx or a 9xxx number.
posted pic of numbers but some are kinda rubbed off, still cant really tell what the numbers are, please help me find out if i have what i was told i have,
Thanks Robert
Thanks Robert
I am thinking the number is 9072 which is off a 1975 360 cu in. California N95 application.....
Thanks bbrroowwnn, ill change this then i was lead to believe it was a 340 carb, this being said whats this carb worh as i would think a 75 360 is gonna be worthless than a 72 340 carb.
Thanks for all your help
