prochamp98
Member
Got a ? about installing super stock springs. I installed a 3" spring relocation kit from mancini. The shackle angle is different on the left side from the right side. Is this normal since the springs are different from left to right. Will it work ok like this. When I installed the relocation kit I kept my measurements the same on both sides. I was told they need to be the same when installing super stock springs.
