[FOR SALE] Selling off my turbo parts and super six intake
kkeith1986
Wheaton, Il
I have decided to just drive my car like it is. I have a collection of parts that I am just going to sell so I figured I would post them on here to see if anyone is interested first. Most of the parts I will ship except the items that are marked (will not ship) I will upload pictures this weekend once I get some time
Holley 2300 350CFM 2-barrel - Brand new and I have modded it for a blow through setup according to the hangar mods. Also includes a jet kit with #64 - #99 jets. $350.00
Turbonetics Turbo - Only number I can see is a 20192 on the compressor side. I got it from a guy who running it on his grand national and decided to upgrade to a bigger one. The shaft has a little play in it but it has been sitting for over a year so some oil pressure should firm up the shaft. Since it is unknown I only am asking $150.00 (Will not ship)
Turbonetics Evolution Wastegate - It is in used condition $85.00
Lokar 904 downshift cable - Brand new in packaging. Part # KD-2904ht SOLD
Lokar throttle cable - Brand new but not in packaging. 24" cable with brackets - SOLD
Procharger low profile carb bonnet for a 4150 carb. Will include 2" spacer $95.00
Innovate MTX-L Digital Wideband Air Fuel Gauge Kit 3844 - brand New - Sold
AUTOMETER PHANTOM MECH 100 PSI OIL PRESSURE GAUGE 5721 - 2-1/16" brand new $37.50
TurboWerx Base-Model Electric Turbo Oil Scavenge Pump with filter screen. Brand new and is supposed to be the best remote oil pump on the market $200.00
Supersix 2 barrel intake - Cast Iron with 2300 carb adapter plate - $125.00 (will not ship)
I accept paypal only and will be shipping from 60189. PM with any questions and for shipping quotes.
A little more info on the turbo: Compressor side is a 2.5" inlet and 2" outlet. The turbine side is a undivided T-4 flange and has a 3" outlet with a round 4-bolt downpipe flange. I have the downpipe flange and can sell it with the turbo for an additional $20.00.
The Wastegate is 38mm's and comes with two springs. One spring is inside and I believe its the heaviest spring around 9psi and then I also have a white spring which I believe is a 3psi spring.
I am also selling off the start of my turbo exhaust manifold. It has 1/2" mild steel flanges with 304 stainless elbows coming off of it. The elbows have been just tacked on with 309l wire due two the different types of metal. I have a few hours into this with trying to get the round pipe to fit the rectangular ports. Asking $150.00
The Carb bonnet has a 3" inlet.
Good guy here yall. He gave me a part number on some stuff, even though I was not a buyer. Here's you a bump, Keith. We gotta look out for the good guys.
A little more info on the turbocharger
Compressor wheel measures 2.225 / 2.960
Turbine wheel measures 2.452 / 2.882
The compressor trim I think would be 88 and the turbine trim would be 115. I am not 100% sure I calculated right and I used a shitty caliper to measure the wheels so its not 100%accurate
Still can not find anything on the A/R size because measuring that is difficult and there is nothing stamped anywhere on the turbo
The header flange is for sale. It was the start of a turbo manifold that I am just not going to finish because I changed plans. The flange is 1/2" mild steel with 304l stainless 45 degree elbows tacked on with 309 wire. I have a few hours into because I had to square the tubing to make it fit the rectangular ports. I am asking 150.00 for it but make an offer if you are interested. I really have no use for it now unless I decided to build the turbo manifold and sell it complete. Which I really don't have the time right now to do.
