swinger340
How is your geometry? Could shim the rocker shafts and go with aftermarket adjusters w jam nuts. The factory one tend to back off sometimes.
What baxter61 said is a possibility. The pushrod cup may have made contact with the rocker.
. Also make sure shafts are not mounted upside down.....
I guess you didn't see the rest of the thread.................
Bits and pieces, but after going back and reading the whole thing, I see you have mentioned everything I said. More opinions, the better I would think. He ask a question and I gave my 2 cents.
the guy thats there now, says the shaft upside down doesnt matter on this style rocker, only the stamped steel rocker.??
Their response was that those were the only ones they could get for adjustable rockers. I've lost what ever faith I had in them today after talking to them.
I have a set push rods that are shorter. Not a huge amount, butt the amount they are shorter, would give more clearance at the rocker.
I will go measure one of each.
