[FOR SALE] Swirl Port 360 heads
simplebob
Active Member
La Plata, MD
Rating - 0%
0   0   0
this set of "308" casting number swirl port heads came off of a running 360 engine that was used for a stroker build, engine had 89K miles and ran well. Heads can be cleaned up to use on a driver or rebuild for a performance engine. come with the shafts and rockers, price $100 OBO plus the ride.
located in La Plata, MD can be picked up locally or even at the MIR Mopar Eastern Classic on October 19, 2013
im interested, can i see i pic with a straight edge across valve tips? and a shipping quote to 90802 long beach ca. ? thanx in advance
it is dark outside , so I will get you the picture with the straight edge tomorrow after I get home from work and get you a shipping quote.
thanks,
Bob
FYI, it was about $60 a head coast to coast last time I sent them Fedex, but get accurate quote from Bob. Thats a good price on those heads.
here is the pictures with the straight edge, they valve tops line pretty well. A few valves are down by a little (less than .005") , probably due to some valve stem wear. Each head has one exhaust bolt broke off that will need to be repaired. Heads have some surface rust from sitting for several years, nothing all that bad, not much corrosion in the water passages.
PM sent about the shipping costs
