Grand-Spaulding Dodge - Mr Norm's
69 Cuda 440
Legandary Member
Legendary Member
Wilton, Connecticut
Some early 'Performance Packages.
1967 Dart GTS 'GTN'
A 383/280 HP, with a 'Street Performance Package' installed by
the Dealership 'Performance Department'.
Take your 1967 Dart GTS 383 from {15.30's @ 92 MPH} to {14.60s @ 96 MPH}
with our 'GTN' Package.
'GTN' Street Performance Package............$363.65
Thanks Men,
I'm pretty sure that Newspaper Advertisement was from March 1967,
Just after the 67' Dart GTS 383 was introduced on February 10, 1967.
Great thing about Grand-Spaulding, was that they had a 'special discount' and
'easy loan package' for the U.S. Military Personnel {returning G.I's from Vietnam}.
They really wanted to push the Musclecars back then......
Eddie,
According to Mr. Norm,
The 1967 Dart GTS 383 'GTN' {Stage 1}
After 'performance modifications', the GTN 'Stage 1' put out
390 Horsepower @ 5000 RPM's to the rear wheels on the Bear Dyno.
Mr. Norm {Norman Kraus}
Projected that the 1967 Dart GTS 383 'GTN' was capable of 13.80's @ 102 MPH, with a set of 4.10 Gears.
Norman Kraus said that his Dart 'GTN' could outrun a 'stock' 1967 426 Street Hemi Coronet R/T.
A pretty bold statement for a 383/280 HP with just 'Street Performance' bolt-ons.
'GTN' 'Stage 1' Street Performance Kit
* 3.55 Gears w/Sure-Grip {Optional Gears; 3.91 or 4.10}
* 'Kustom' Tuned-Headers
* Low Resistance-Flow Mufflers
* Re-Jetted Carter AFB {575 CFM} Carburetor
* Dual-Point Distributor w/Performance Curve
* High-Performance Ignition Wiring
* Performance Tune-Up {Autolite A-42 Spark Plugs}
* Dyno'd at 'Mr. Norm's Performance Shop' by Racing Specialist; Frank Oglesby
Thanks man! That's so cool! I would take either one of those for my car! Set of four, for only 84$
'Astro Wheels'
A Cragar S/S 'knock-off', available in 3-Choices; 'Supreme', 'Custom' and 'Standard'.
Mr. Norm's {1967 Advertisement}
* Mini-Bikes......$139.95
* Racer Brown SSH-25 Camshaft (Big Block Mopars}..........$79.95
* 485" Lift ~ 286* Duration ~ 56* Overlap
* Big-Block 'High Load-Rate Valve Springs' {Set of 16}.......$19.36
67 383 Coronet Deluxe, eh?
Thanks for sharing 69 Cuda 440.
I met Norm at Carlisle in 2010, he was with the Challengers that were converted to Cuda's with a supercharger on them.
'GTN' Street Performance Package............$363.65' , Dam this seems to cheap to believe.
Keith,
I know, kind of unbelievable.
'Kustom' Tuned-Headers {Under-Chassis}, with Hemi-type Mufflers, and
installed, part of that GTN 'Stage 1' package.
And, swapping out the 3.23 Gears, for a set of 3.55 cogs.
Re-jetting the Carter AFB and re-setting the 'Pump-Shots and 'Float Level'.
A 'Dual-Point' Distributor, that is set with a 'Performance Curve' on the Sun-Scope
Distributor Calibration Machine
High-Performance Ignition {Spark-Plug} Wiring.
Autolite A-42 Spark Plugs.
Car pulled on the 'Bear Dyno', and fine-tuned.
R/T,
There is/was some debate as to who just 'popped' the 383 in the 1967 A-Body first,
Plymouth - Dodge or 'Mr. Norm' {Grand-Spaulding Dodge}.
Mr. Norm made the claim that is was him first, but Plymouth had already installed
the 383 in the 1967 Barracuda in August/September 1966.
Mr. Norm's {Grand-Spaulding} Dart GT '383' project started in December 1966.
As per Chrysler {August 1966} they only planned on offering the 383 in the 1967 Barracuda 'only'.
Wonder if any of those have surfaced?
Might be the next big thing.
Kind of a pre- Super Bee thing.
1967 Dodge Coronet 'Deluxe' 2-Door Post Sedan 383/325 HP
Production Numbers
* 'Automatic'...........345
* '4-Speed'...............25
I have seen a lot of Mopars, but I don't think I ever saw a 1967 Dodge Coronet 'Deluxe'
with a 383/325 HP '4-Speed'.
Yes, a much 'pre-weakened' version of the 1968 Dodge Super Bee 383/335 HP
Why would you say much weakened?
A- because logically It can't be weakened if the Bee hasn't been produced yet, and
B- It's 10 "book" HP, and a lighter car.
With a Mr. Norms tune I bet it performed the same.
'Pre-weakened'.......
The difference in 'Shipping Weight' was not that much, only {72 lbs.}.
* 1967 Coronet Deluxe...... #3388 lbs.
* 1968 Super Bee............. #3460 lbs.
Book Horsepower on the 1967 383 4-Barrel was 325 HP, but it was much closer to
280 to 290 Horsepower.
* #516 Cylinder Heads with a 1.60" Exhaust Valve.
* Restrictive Exhaust System
* Mild Camshaft {Same as 383 2-Barrel}
* Weak Valve Springs
* Low-profile Intake Manifold with poor flowing Runner-Ports
* Carter AFB {575 CFM}
All you have to do is look at the 'anemic' Production Numbers, and you
could tell that the 1967 383 was 'not' a Street Musclecar.
Grand Spaulding Dodge {Mr. Norm's} did have an 'Upper Engine Kit', for the 383 which included;
* Racer Brown Camshaft 'Hydraulic' and High Load-Rate Valve Springs,
* Edelbrock Aluminum Dual-Plane High Rise Intake
* Holley 600 CFM Carburetor.
That got you going in the right direction.
Mr. Norm's 1967 Dart GTS 383 'GTN'
There was a Stage 1, Stage 2 and Stage 3.
Anybody know what was in Stage 2 or Stage 3.
