video of Duster(5.80 pass)
This guy is good,he can't lose with two identical cars in the same race!!!
keep up the good work JB......
PETE......................
I've loved the car since you got it. Thanks for the video's. Loved seeing it run. Nice clean passes on what looks to have been a fairly cool day.:thumleft:
The completed setup(tuned&built),shows in the confidence of a proven combo. The less confident guy,always goes to impress....
Thanks for the kudos .I hope to get another 30-40 hp when I dyno it in a month. the converter needs to need loosened up a bit and maybe a little more gear.
Awesome! If that doesn't bring a smile to your face something's wrong! Nice job...thanks for sharing.
That car rock's very nice job..AWESOME :headbang::headbang:
Could you spill some secret sauce?
What……...
1) Compression/Fuel
2) Trans used
3) Stall & Valve Body used.
4) Rear end set up -Make & Ladder bars etc?
5) What Gear are you running.
6) Tire size
Thanks!
What……...
1) Compression/Fuel
2) Trans used
6) Tire size
Thanks!
4in Callies with 2in rod journal
4.185 bore flat top
Coleman/Arrington W8 head 2.18x1.625 titanium valves
heads and intake done by Brett Miller
roller cam spec bye Brett Miller
T&D 1.7 rockers
420 intake with a Dominator flange
comp is 15.4
6.30 Carrillo rod
Glide with a 1.80 gear
29.5x11.5W tire with a 4.56 Dana
Carb is a Bob Book dominator(C12)
will try C14 next year.
