your dart
71gtdart
sc
what model is it and what is its weight WITHOUT you in it? I'll be weighing mine in a few weeks, but was looking to see how heavy similar set ups to mine are.
mine is a 71 dart with an iron head small block. has 29.5 x 9 slicks, gutted dash and firewall, full cage, and one racing seat. two optima batteries and a 5 gallon fuel cell in the trunk. Willwood disc brakes on the front and factory drums in the rear. only fiberglass is the hood.
thanks in advance.
fiberglass bumpers....fiberglass hood and trunk lid...one seat...8 pt roll bar..2 batteries in trunk...5 gallons fuel cell....Strange front brakes...stock rear drums...aluminum radiator and eddy aluminum heads....ladder bars and coil over shocks.....10 x 29 Hoosiers and 15 x 8 drag lites.
Last time we weight the CAR....2745 no driver...maybe lighter these days...
71 Dart
My 75 dart se has a 318, 904, and 7.25. With 14" bfg radials on steelies all around. Full bucket seat interior street trim, no a/c, with power steering. Huge bumpers with absorbers, One battery. Spare tire removed and about a half tank of gas
3400 lbs without me. Ya she's heavy. Lol
71 demon, dana 60 with drum brakes, ladder bars, coil-overs in all corners, aluminum wheels and lite weight drag tires, 12 pt cage, fiber fenders, hood, frt bumper and splash pan, all stock glass, vinyl top, 9 gallon fuel tank in frt of core support, one gallon in trunk, 1 battery, 1 electric fuel pump, 2 fiber seats, no back seat, stock console and dash, carpet, all aluminum motor, headers, 5" exhaust to rear tires, moly drive shaft with safety loop, 2"x3" frame connectors and 727. 3500lbs.
69 Dart 425W5 29.5 10.5 tire 9in ford tubular K member all steel glass hood 1 battery 12 gal cell. 2865lbs no driver.
70 Dart with a sb, full interior, full tank of gas and a full size spare in the trunk was 3330lb.
Thanks for the replies. judging by the info you guys have shared I'm guessing that mine is going to be around 3050 to 3100 lbs without me in it. maybe a tick lighter, who knows?
74 Dart Sport. 440 Aluminum heads, radiator, and water pump housing. 833 4 speed. S60 rear end narrowed 4". Power steering. 8 pt cage. Aluminum fuel cell. 2x3" steel frame connectors. Lightened rear bumper. No heater box. 3550 w/o me.
1975 Duster 396 stroker w/alum heads/intake/radiator, 833 trans with scattershield,3" driveshaft, S60 rear end, disc brakes all the way around, aluminum rims, roll cage and frame connectors, 1 battery in truck, stock gas tank ~9 gallons in it, two bucket seats in front/bench in back, heavy as heck stock bumpers. 3440#
Currently switching to fiberglass hood, deck lid, front/rear bumpers and took out the rear seat. Hoping to get down to 3100# or less, I should know in the next few weeks. :burnout:
68 dart, iron headed 383, 727, 8 3/4 w/35 spline mosers, spool, disc's ladder bars with coil overs. Stock front suspension, manual steering, steel body except fiberglass hood. 10pt cage, fiberglass buckets, back seat, no heater. 12 gallon fuel cell and 1 battery in the trunk. 15x3.5 pro stars w/ 165r15's, 15x10 pro stars w/ 325/50-15's. Car weighs 3190 with out me in it.
73 dodge dart. all steel with a plastic hood scoop.factory disc brakes up front, B-body drum brakes in rear. 8-3/4 axle. no roll bar, one not so heavy stock drivers seat. Indy ez headed 440, aluminum rad/water pump, tunnelram etc. weld drag lights 15x3 in front 15x8 in year. weighs 3520 with me in it. hope my soon to be 73 duster race car is lighter.lol mopar65
I'm sure the Duster will be lighter. the big block is what really hurts the Dart. I can't confirm, but always have read and heard that a Mopar RB engine is almost 200 lbs heavier than a LA small block.
My old bracket car is a 67 Belvedere. it has only a single plastic race seat, 6-point cage, no carpet, a iron head 440, 727, 8 3/4, weld drag lites, aluminum intake and radiator, 5 gallon fuel cell, and 27-10.5-15 street radials. it weighs 3350 without me in it. all steel with a glass 67 Super Stock hood scoop.
72 Dart Full steel body, full interior, cage, frame connectors, aluminum wheels, fuel cell car weighs 2980 with out me. Small block aluminum heads and intake. My brothers 72 duster iron headed small block weighs almost the same. 1 pound difference, we couldn't believe it.
how did you get that Nova hood to fit your Dart that well? LOL
National record holder chassis God J. Caughlin can do anything.
The only thing I wish I would have done is have it go to the window.
This under car scoop do's work.LOL
67 Dart 4 door sedan,prepped for the drags, all steel other than bumpers.Built slant six (Add 50 lbs for a V8) )race weight 2625 lbs.
68 Dart, 363 W2 headed s/b, 904, glass trunk lid, hood, and bumpers, Nissan aluminum radiator, front bench seat, no back seat, 8 gallon cell, one rear mtd. battery, mini tubbed, narrowed 8 3/4, 15x4 Welds on front , 15x10 with 29x11.50 QTPs on rear: 3150lbs with me , 2935 with out
real nice combo
Thanks. Will have eddy heads on it once i get my lazy tail out in the garage to put them on.
