Just wondering if there is any way I can get some extra oil onto my hydraulic flat tappet camshaft before I start it up. I put cam lube on it as instructed, and put some heavy weight oil on it as well, but I'm sure alot of it wore off as I turned it to adjust the rocker arms and turning the engine for whatever other reason (Had some trouble tightening the crank bolt!). I haven't put oil in it yet but is there any way I could get some more oil on it? Intake manifold and everything is installed. Engine is still on the stand so can I angle the motor and pour my break in oil through the heads to get some on the cam?
Probably a stupid question, I just don't want to loose a cam when I start it. Or am I worrying for nothing? and will everything be fine as long as the motor starts up immediately and I get the revs up, and prime it of course?
