PLTO6
New Member
I have been tasked with selling this 1967 Plymouth Barracuda Notchback Project for my daughter that acquired it from her divorce
My son-in-law purchased the car from the original owner family almost 2 years ago as it came from the factory. The car has never had collision damage and does not have rust. Original paint is in excellent condition with only a small number of minor dents/dings. This is a rust free survivor with 41,000 miles.Interior is complete and in showroom condition. There is over $40,000 invested in this project and I have receipts, California title, letter from original owner relatives and other documents to prove what Im saying. This would be an excellent buy for someone overseas since everything has already been acquired. I would like to get around $25,000.
Brand new Mopar SRT8 Hemi 6.1 litre crate engine
Complete New Magnum Force Racing XRT A-Body K-member and front coilover suspension (powder coated and installed). Includes power steering rack and anti-sway bar.
New Performance Suspension Technology rear leaf springs and Bilstein shocks.
New Rock Valley stainless steel gas tank with in tank EFI fuel pump
Brand new Moser 12 bolt Musclepak rearend
Package includes; New Moser 12-Bolt Made in the U.S.A. Housing, with OEM located mounting provisions, seamless steel tubing (3" O.D., 1/4" wall), custom alloy 30 spline bolt-in axles, bearings, studs, seals, heavy duty retainer plates, new housing ends, t-bolt kit, Eaton clutch posi, "1310" Series pinion yoke, ring & pinion, chrome rear cover, set up with Timken bearings, New 9 1/2" GM Drum Brakes, brake lines, brake line clamps, emergency brake cables.
Includes Painless Performance Products Mopar 14-circuit wiring harness (new in box)
Includes Custom Speedhut Legacy Barracuda 6 Gauge Set (new in box, speedo, tach, water temp, fuel, volts, oil pressure & senders)
Includes 5 Vintiques Mopar Steel Rally Wheels and Cast Center Caps. New tires
Includes original automatic steering column and professionally restored manual steering column.
Needed to complete:
- Engine has never been started
- Engine wiring harness and computer is included. Drive by wire throttle pedal.
- Includes power steering pump, alternator and AC compressor.
- Ceramic coated tight-tuck headers
- Original hood is included and clears Hemi motor (no modification required)
- Wilwood front disc brakes and master cylinder.
Needed to complete:
- Radiator and hoses (parts not included)
- Install steering column and wiring harnesses (parts included).
- Brake and fuel lines
- Muffer System
- The car is in San Diego CA.
