I was wonderin the same thing with Dads 273. LD4B has no coil mount....member here told me to use a 340 6pk coil bracket. Slight grind to the bracket and fits perfect...and stock
I tried that and it looks like crap...sold the 6pak bracket to another member...get the MSD one....i'll post the number for you, it mounts using 1 intake bolt hole IIRC and holds just fine and tight....plus looks cleaner than a firewall mount :glasses7:
My Mopar M1 didn't have a spot either but I used a MSD coil bracket and got it to line up using an intake bolt hole, I have an extra so if you are interested in it i'll give you a killer deal on it......FABO Discount :glasses7:
BTW, it would mount the same as mine in the picture...I can get better pics if you want and the bracket is still new!
I have a 318 with a Weiand Action Plus intake.I really do not see anywhere to mount the coil on the intake.I do not want to mount the coil on the firewall.So where are you Guys mounting your coils?
I do not like the looks of the coil mounted to the inner fender or firewall.I have made a bracket that mounts to the rear of the intake on the passenger side.I made 3 and sold two of the brackets.I will be making about 10 more to sell later this week.I will post pics later this week.
The brackets I am making mount in the same spot on your intake as post #9.
Hey Jim, Im curious if you got pics of the one you made?? Also how much $$ ?? Pm me for my email.
Thanks
Steve
