What wheels are you running?
Was considering 17" gold Dazzlers for my ride, but this GM sided world decided that they shouldn't be offered in gold and the 5x4.5" bolt pattern! So now I'm leaning towards Cragar Eliminators in gray.
Anyone know the bolt pattern, offset and backspacing and any other info I need for wheels? I don't know ANYTHING about wheels haha (1970 Dart)
15"x7", 4.25" backspacing, 4" bolt circle, E-T Classic V wheels. 225/60-15 BFG tires:
First was 14"x6" Keystone Klassics (195 front, 215 rear). It now has 15"x7" American Racing 200Ss with 3.75" backspace (225/50/15 Kuhmo Ecsta ASTs).
Kegan that looks great, when did you put those on?
I'm digging those on that car. Was it extra bullshit to get those in the small bolt pattern? Seems like everything else is. Curious where you got them. Perfect replacement for my ralleys.
Torque Thrust D's 205/60/R15 with adaptors to LBP
Thanks! E/T will drill any bolt pattern you want. You can use their supplied "nuts", which are just threaded tubes with a broached internal hex (for an Allen wrench). Although perfectly useable, I did not like them, so I had a machine shop custom make the lug nuts you see in my picture. Contact http://www.etmags.com/ for wheel info.
Weld Pro Stars: 15 x 7 rear, 15 x 5 up front
