[SOLD] TTI 340 Shorty headers
csingle5
ok
TTI 340 shorty headers ceramic coated unpolished. I placed a smooth dent in #3 cylinder tube for power steering gear. Comes with headpipes. Used only 200 miles. I like, but I have more exhaust than I need. On the pictures. I only have pictures of the right side, but the left side is just as beautiful! $500 plus shipping.
How big a dent? Pictures? Also, how was the fitment besides power steering you mentioned? Head pipes have good clearance? I see you said 200 miles, but how old? thanks
more photos
more photos: The left head pipe that has a dent is factory placed, for auto column shift. It can be removed from inside out; should you not have column shift. The clearance dent in # 3 tube is approx .180 deep x 1.5'' long note its direction to flow also it was not highly visible when installed, I had photo failure hence no installed left photo. Further I was to picky about scratches and painted v.h.t. on left header it stuck real well but you could remove if it was bothersome. It did not look much different from right header.
in my car is a mini starter
I looked on the tti site, it calls out specific starter part numbers. I was looking last night while removing a sloppy power steering box like how in the hell is a header going to fit in here! Giant factory starter is gonna have to go
very vry tight clearence
torsion bars go through the header and steering goes through header too
gotta pull motor to get the headers out and on nutzz
