oK shorty's are almost in as I'm waiting on the Rob Mcc starter to get here for final install on drivers side.The pass side slide right in no problems at all and used all the factory studs,nuts they are much better than header bolts in my opinion. Driver side not so good but remember I am using the untested by TTI Borgeson box. After several shim attempts, new motor mount I had to put one ding in the #3 tube just below the one TTI puts in for box clearance and use a 3/16 shim on drivers side mount, I only have to use 1 header bolt on front tube 2nd hole.The Z-bar in my car fit perfect so I did not need the one ordered from TTI. Only real complaint I have is the pass side head pipe points towards the driver side muffler not strait back like the drive side will. Sorry no Pics as of yet, I plan on using heartthrobs 2.5 exhaust w/hvt? mufflers If I remembered that right, yes they are not an x or H pipe system But I can H them later If I like. I Hope this makes sense and maybe help some one.
69 Dart GTS factory BB 383 car now w/fresh 67 GTX 440 :glasses7:
