This is a thread documenting the build of my 1971 Dodge Demon which I've named "Pazuzu". Brownie points to whomever knows that reference.
So, the overview of what I have. (For both you and I to keep track of)
1971 Dodge Demon:
-1972 Grille
-318
-a-833 with reverse gear to the left and to the back.
-7.25 read end (SBP all around)
Needs quite a bit of work.
What I've fixed so far:
-Ignition switch (would turn the key, and unless you held it in a certain position the vehicle would turn off. New ballast and that's fixed)
-Door locks installed.
-Parking Brake now easily works.
-Brake pedal has been tightened.
1971 Dodge Demon:
-1972 Grille
-318
