j par
Well-hung Member
I was wondering if some hillbilly slapped together Some budget cheap 410 Stroker with Stock Smog heads if it would have a chance against a 340 x block with a genius Machinist working on it?
Top end makes the power (cam, carb, heads, bore, CR etc...) bottom end (cubic inch) decide on where that power is made (powerband and peaks).
Win on Sunday sell on Monday. THAT sells cars. I remember by dad used to say that a LOT when referring to mopars...410....Depending on some things like headwork and cam choice.....2nd through 4th will rev into 6800/7000 if this hillbilly is with his wits...
so will a 340......
Now you tell me ,again, what wins races and what sells cars...........
I know exactly the question being asked
Will J par beat Yellow Rose?
Where ? The Durango is only good for pulling a car flat land. I can't pull the car over Mount Hood to Madras or something like that. And if I'm going way up in to Washington or something I'm pulling out the motor home or something like that spend the night and make a weekend of it. I know PIR is close and cheap I don't know why you have to make things difficult but whatever we would be at the same disadvantages of the crappy track but at the great advantage of it being close and affordable
Because even though I have made hundreds and hundreds of runs at Delta Park I freaking hate Portland. I get a rash when I get near multnomah county. I throw up in my mouth when I hit Troutdale.
If you came my way, we'd have the exact same number of runs down my track. Zero.
I still have to get the two step hooked up and an alignment. Last time I made an appointment to get the alignment done, it snowed for 3 weeks.
looks like snowmobile to me...This is last Sunday - you can't get much more in the hills in Oregon in the winter then here...
What's the problem??? Stud your slicks.............................
^^^ looks cool, but I already have to many traction problems.
STUDS!??Might be the answer.....................
Horsepower sell cars , torque wins races.Win on Sunday sell on Monday. THAT sells cars. I remember by dad used to say that a LOT when referring to mopars...
