Hardtop Side Window Trim for Gap?
Soren
Salem, Oregon
This may be a dumb question, but hopefully not too dumb...
I have no idea what it is called or what I need to order for the trim pieces or seals or whatever they are called for the gap between the side windows on my '63 Dart GT. I also need to find the pieces that go between the door and the glass that keeps them from rattling.
So, what are they called?
The ones next to the glass are called belt line window sweepers. Temecula Valley Mopar has them for 64-66 Barracuda, not sure if they have them for Dart or if they interchange. The other pieces, I'm not sure.
I'm pretty sure you will have to get a used set of trim for that. There are sure to be a lot of swap meets coming up nation wide. See if you can enlist some help from members to look for a set for you. Steele Rubber has a lot of stuff, but apparently not these for your year.
The vertical piece is called 1/4 window seal.
I think i have a spare piece that goes between both windows. Have you pulled the door panels off and checked in the door thats where i found mine i thought they were missing was driving around and heard a rattle and the were both sitting in the bottoms of their doors.
No, I haven't checked that. Didn't even think about it. I'll check it out. They are missing on both sides of the car. What are they called?
I think its just the 1/4 window trim. Ive seen three of our cars where the guys found the sitting in the doors. Thats where i got the idea to look for mine so its worth a shot.
