FYI, you'll probably get a lot of requests for the frame (sub frame) parts if they are in good shape. I parted out a 67/68 Barracuda and couldn't keep up with the requests for front and rear sub frame sections, including the trans sub frame sections. radiator support and control arm body sections are also a big ticket item. A and B pillars are also always a nice item. Ended up shipping most of it by Greyhound which saved a bunch on shipping making it easier to sell the big stuff. You can weigh the stuff on a home scale and go online (Greyhound), punch in your area and the destination and the length of the part and you'll get a close estimate.
I ended up buying a spot weld remover (Harbor Freight, they are cheap) and it paid for itself 1000 times over. People need just about every single piece of sheet metal from front to back and if you use a spot weld remover the parts come out nice and clean.
Hope this helps.
treblig
